markg1
Jun 11, 2011Aspirant
Trouble backing up to/from Win7 machines
i have a readynas PRO that has been working fine for quite some time. the environment was mostly winxp machines and one win2000 box, and i could read and write to each from the readynas. i have ...
MarkA73
Jun 15, 2012Aspirant
Hi
I too have been having the same problem as those above. I have been trying to back up my photos from my computer to the NAS. The test connection button always fails, but if I saved the options anyway I could run the backup process but no files would transfer. I tried all sorts of configuration in the path names and adjusted many settings within my Win 7 share options but nothing was working.
However.....
I just uninstalled Windows Live Sign In Assistant (using the windows remove programs feature from control panel), restarted the computer and tried again (without changing any settings within the Frontview).
The backup is now running and I can see files in the backup share folder on the NAS!
Hurrah!! :D
I hope this helps some of you out there too, it was driving me mad trying to work out what I was doing wrong.
Good luck
Cheers
Mark
I have an Ultra 2, Radiator 4.2.20 and Win 7 64 Bit Home Premium
However.....
Hurrah!! :D
Good luck
Cheers
Mark
