markg1
Jun 11, 2011Aspirant
Trouble backing up to/from Win7 machines
i have a readynas PRO that has been working fine for quite some time. the environment was mostly winxp machines and one win2000 box, and i could read and write to each from the readynas. i have ...
rclark
Jun 19, 2012Tutor
I think there is definitely something broken with FrontView backup.
Just noticed this same behavior on my ReadyNAS Pro 6 running 4.2.20.
I have 2 backup jobs for a couple of Win7 64-bit machines - both jobs indicate they completed successfully, but with 0 files copied. Test connections fail for both and the browse button greyed out. These jobs used to work just fine and I'm not sure how long they've been broken. Played around with user IP vs. hostname, new shares, no security, FW turned off... nothing.
-Randy
-Randy
