alystair
Jun 09, 2006Aspirant
Tutorial: Setting up Roaming Profiles from scratch!
Mini-tutorial on roaming profiles: This is on a Windows 2003 Server, we have not purchased our ReadyNAS NV yet, so this thread will be updated once we have one for ReadyNAS specific options/settings....
Conn
Aug 18, 2009Aspirant
ticklemeozmo wrote: 'Authenticated Users' doesn't port over from the Win2K3 Domain when you list the groups, therefore you cannot set it as part of the groups.
That's what was holding me up. On the setup steps it was a permissions issue, which was solved via the ownership tag.
Computer Configuration > Administrative Templates > System > User Profiles
Do not check for user ownership of Roaming Profile Folders = Enabled
Thank you mister.
I have set this policy for some test users in my AD, yet windows will still freak out if I manually create the users' folders for their profile. The only way I can get roaming profiles to work is to let the user account create the profile folder itself. This isn't quite an issue because I'm still able to access the folders despite them being owned by a specific user and the users can't access each other's folders.
