TheGrayGhost
Aug 10, 2012Aspirant
Two NAS1 shares under "shared"
I am new to using the Duo and set up the drive with an AFP share. In the "Shared" area of the finder window I see two NAS1s listed, NAS1 and NAS1 (AFP). I cannot connect to the NAS1 share, but can c...
Sep 01, 2012Guru - Experienced User
You will need CIFS enabled for Windows at least. If you put that back, then you can access everything normally? That is, the only issue is the multiple advertisements?
