Radiosutch299
Aug 12, 2018Aspirant
'Two Raid Group
HI folks, can you help?
I have a RN316 6 x 10TB disks - all running ok in Raid 6, one Raid group
I plugged in a EDA500 expansion box , (5 x 4 TB disks)
It wanted to expand the volume. no d...
Radiosutch299
I'm running 6.9.3 OS and the chatline not an option, I bought it earlier than 2014
Aug 12, 2018Guru - Experienced User
Do you have full access to the files?
Is the system still in XRAID mode or has it changed to flexraid?
- Radiosutch299Aug 12, 2018Aspirant
Thanks Stephen
Yes,
I can still access files. Apart from showing two raid groups all appears normal.
The button does not show green. I have to say I don't remember if it usually did. Pic atttached
- mdgm-ntgrAug 13, 2018NETGEAR Employee Retired
Did you always have 10TB disks in the NAS since the last factory reset or did you start off with smaller capacity disks?
- Radiosutch299Aug 14, 2018Aspirant
HI
No I had 6 x 4TB
Swapped them out 1 at a time to 10TB.
Althought I THOUGHT this only went wonky when I plugged in the EDA500 it's certainly possible I didn't notice I had two raid groups after the volume expanded. 4>10 disks. Thinking back, I was expecting the volume to resize when the last disk had been added but it expanded before that. I don't really remember but there was something strange.
I'm thinking I need to back up and do a factory reset. That would no doubt fix it. The only think against it is the time it takes to resync 6 disks
