torer
Dec 02, 2013Aspirant
Two RN516 units: missing shares after rsync
Hello! I have two RN516. When I installed the second unit, I did a rsync from the /data/* directory to the target RN516. The problem now is that the one of the folders, /data/Repo, was initiall...
Dec 02, 2013Guru - Experienced User
You could also try renaming the folder, creating a share, and then renaming again so the original folder is again called "Repo".
I think that will work. I'd turn snapshots (e.g. "continuous protection") off initially. You might also need to reset file permissions when it is done.
EDIT- make sure that the current Repo folder is a btrfs subvolume before you try this.
