mark-in-seattle
Aug 05, 2018Aspirant
Ultra 2+ Powers On - No ethernet activity - Corrupt Firmware ? - USB Boot Recovery NOT Working
Any help or suggestions appreciated.
Helping a friend recover the use of his older ReadyNAS Ultra-2+ which does not boot into the NAS's system management webserver or even attempt to send ethernet ...
mark-in-seattle
Aug 06, 2018Aspirant
USBRECOVERY.EXE - What it does and does not do ?
.... so the Netgear USB boot recovery program: "usbrecovery.exe" (53 KB) I ran under WinXP did not appear to generate a linux boot loader file(?) "ldlinux.sys" to place on the USB memory stick target and no file like that was extracted from the original Netgear USB-Recovery zip archive either.
At 53 KB I'm not sure "usbrecovery.exe" would be able to make my FAT32 formated USB memory stick target "bootable" either. Probably as Mdgm mentions in an earlier post, it is up to the user to find a USB memory stick compatible with the ReadyNAS (Ultra2+), partition it properly, format partition #1 as FAT32 then run "usbrecovery.exe" linking it during creation/runtime to the correct RAIDiator firmware file in the same folder as the extracted USB Recovery utility files and finally help the ReadyNAS use the firmware file to replace it's current (possibly corrupted) firmware file stored in internal flash memory.
Why Have My Earlier Attempts to Use the USB Recovery Method Not Worked ?
Initially did not integrate the RAIDiator Firmware file (RAIDiator-x86-4.2.31 (56,026KB)) onto the USB memory stick ... operator error. Corrected that but still the Ultra2+ did not seem to initiate any conversation with the FAT32 formated USB boot recovery memory stick.
Had not done anything special on my part to make the USB memory stick "bootable", or partitioned/formated in any special way other than as FAT32, assumed those details would be done by "usbrecovery.exe". Not a good assumption in retrospect since usbrecovery.exe also did not place the "ldlinux.sys" file on the USB either. Maybe "ldlinux.sys" isn't really used by the ReadyNAS during the boot recovery, however Mdgm mentioned it should be present on the USB in an earlier post and it was not until I installed SysLinux v6 on my WinXP system ran the CLI command "syslinux.exe -m -a G:" , (from the SysLinux wiki) "-m" installs suitable MBR code into your flash drive and "-a" marks the partition on it as active. G: is my target USB memory stick. I also tried using RUFUS to prep the USB stick as bootable ..etc.
These modifications still did not engage the ReadyNAS Ultra2+ in any discernible positive response when I tried the USB boot recovery procedure.... dang. On the desperately positive side, at least one can say the Ultra2+ still did not seem to like the USB at all and did not pull any files off it (my USB stick has an activity LED). If it had acted like there was a reasonable data transfer and STILL no good outcomes, no ethernet port activity, then well maybe a hardware fault in the Ultra2+ was the source problem.
What to Try Next
Read many SysLinux wiki pages last night to gain a marginally better idea of the USB boot process using that tool, which seems to be used by NetGear for ReadyNAS. Will try different USB memory sticks, because even the SysLinux wiki mentioned CHS (Cylinders - Heads - Sectors) geometry translation on USB sticks is a huge pain and confuses many small computer systems. My guess is that nice low energy CPU's like ones used in the ReadyNAS do not have enough physical or logical memory address space to accept every lame CHS geometry used by a multiplicity of USB stick manufacturers. Big CPUs have address space to burn and aren't put off by excessively wasteful CHS allocation.... just a guess.
Will see if using the most recent Syslinux version is incompatible with the version used by Netgear ReadyNAS USB boot recovery utility, will try using an older version.
More effort to make sure the USB memory stick is partitioned and bootable in a way compatible with USB boot recovery. Anyone have suggestions about this issue ? What procedure did you use to partition and make it "bootable". Has anyone actually used USB boot recovery to fix a suspected internal flash firmware corruption issue on any ReadNAS in the Ultra or Duo or similar series ?
mark-in-seattle
I tried substituting two files provided by Mdgm on the USB stick:
initrd.gz (6.4 MB)
kernel (6.2 MB)
to enable remote diagnostics thru RAIDar (I think) but these would not enable booting either - no ethernet activity or visibility by RAIDar. However, it is likely I did not have the USB stick configured as "bootable" or something similar when I tested this. Will try again.
