beglitis
Mar 31, 2013Aspirant
Ultra 2 vs 102
Hi, Quite simple. Assume they are equally priced. Which one? Ultra 2 has the Atom CPU at 1.8 and more memory. 102 is the latest model with the new OS but seems inferior hardware wise. Both can be...
Mar 31, 2013Guru - Experienced User
The ultra-2 CPU is faster, though the RN102 uses less power. But I think the answer really depends on what services you want to use. If you want the normal NAS services (CIFS, AFP, NFS, FTP), then either device will serve.
If you are interested in the emerging cloud features of the NAS, then the RN102 is what you need.
There are a couple of other features unique to the RN102 - the continuous protection mode (letting you rollback to old file versions), the real-time antivirus protection, SSD disk support, and eSata I/O.
