SixString1
Feb 21, 2013Aspirant
Ultra 4 no longer archiving Tivo files
As of 2/16, my Ultra 4 has been unable to successfully transfer any Tivo files. Nor can I via Web or Tivo Desktop. According to the Tivo Community Forums, this appears to be a widespread problem, evid...
alexofindy
Apr 24, 2013Aspirant
OK, thanks! I had maybe 100 shows that "archived" as 1 KB pseudo-files, and it took a while to select these entries from dump.txt and copy them in to prune.txt. Maybe there was an easier way. A sortable file, like export.csv, which I could have loaded in to Excel, that could be used in lieu of prune.txt would have been nice. (I haven't quite figured out what import.csv does)
Be that as it may, I very much appreciate the availability of a fix; as of yesterday, the latest tivo firmware for my Premiere XL still had the bug, so without the readytivo/readydlna update I would have been dead in the water. Thanks Skywalker for making a fix available.
I did loose a bunch of shows that I had deleted from the Tivo (but life goes on), I will certainly try to follow the forums and double check that things are working more often!
