NASguru
Dec 07, 2016Apprentice
Ultra 4 Plus - Is it worth upgrading from 4.2.30 to OS 6.6
I'm contemplating upgrading from 4.2.30 to OS 6.6 but a bit hestitant given some of the posts with issues of fan speed, write speed performance, etc. I recently purchased a 626 and have already move...
NASguru
StephenB wrote:You can do the upgrade. It requires a factory reset, so you'd lose all the data. It's also useful to check the bios version first.
The benefit of course is that you'd get OS 6 on both systems. That would enable ReadyDR backup for instance. Plus it removes the expansion limits of OS 4.
FWIW, my pro-6 is running 4.2.30. When/if I need a factory reset anyway I'll upgrade it. But for now I'm leaving it alone.
No worries on the factory reset as there's nothing on my Ultra 4 Plus at the moment. I'm uncertain how to check the bios. What version do I need? Good points on the ReadyDR and expansion limits. Yeah, part of me feels I should just leave it as-is since it meets my needs and part of me thinks if I'm going to do it then nows the time since nothing would be lost.
bedlam1
Dec 07, 2016Prodigy
A review of this recent post (for an Ultra 6) https://community.netgear.com/t5/Using-your-ReadyNAS/Ultra-6-OS-Upgrade-from-4-2-30-to-OS-6/m-p/1183368
may help, it tells you there the steps to take and gives links to the files you need.
One link is to an add on to update your Bios, this must be done in OS 4.2.x not OS 6.
I upgraded my Pro 4 to OS 6 some months back and it is now running perfectly, there were some hiccups along the way
- NASguruDec 07, 2016Apprentice
bedlam1 wrote:A review of this recent post (for an Ultra 6) https://community.netgear.com/t5/Using-your-ReadyNAS/Ultra-6-OS-Upgrade-from-4-2-30-to-OS-6/m-p/1183368
I probably should have done some reading before posting, but this helps. Is that BIOS update applicable to all RN regardless of model? I want to make sure I'm not installing a BIOS file for a Pro 4 on an Ultra 4 Plus only to brick it. :manlol:
- bedlam1Dec 07, 2016Prodigy
What Bios version and date have you got currently installed ?
You can check this by downloading your logs and viewing bios_ver.log
The latest version for Ultra 4 and Pro 4 (plus others) is actually Ver 080016 dated 08/23/2011
It shows: 09/20/2010 ReadyNAS-NVX-V2 V1.9
So from your other link StephenB posted: The newest one is I know of is 6/10/10 - the download link is here: http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin
I presume that link is applicable to my Ultra 4 Plus and not just an Ultra 6?
That said it looks llike StephenB posted all the steps needed but it appears I need to update the firmware first while the Ultra 4 Plus is on OS 4.2.30
Basic instructions are
- BACKUP, BACKUP, BACKUP
- Download PREP4TOR6_0.1-x86.bin
- Upload it using the ReadyNAS web gui firmware update, but do not reboot afterwards (avoids the need to do manual factory resets)
- Download R4toR6_latest.bin
- After you upload the addon/firmware and reboot, it will update the firmware and start a factory default.
As you can see it does a factory default, so all data on the NAS will be lost.
