Jophus
Dec 16, 2016Luminary
Ultra 6 6.4.2 disk fail issues
Hey All. Wanted to relay a story to you all around how my Ultra 6 on 6.4.2 suffered a disk failure, rebuilt, locked up, then worked perfectly...
Disk in questions was a 2GB Seagate:
Dec 14 13:38:22 Sextuple kernel: ata6.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
Dec 14 13:38:22 Sextuple kernel: ata6.00: failed command: FLUSH CACHE EXT
Dec 14 13:38:22 Sextuple kernel: ata6.00: cmd ea/00:00:00:00:00/00:00:00:00:00/a0 tag 19
Dec 14 13:38:22 Sextuple kernel: res 40/00:01:01:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeout)
Dec 14 13:38:22 Sextuple kernel: ata6.00: status: { DRDY }
Dec 14 13:38:22 Sextuple kernel: ata6: hard resetting link
Dec 14 13:38:27 Sextuple kernel: ata6: link is slow to respond, please be patient (ready=0)
Dec 14 13:38:32 Sextuple kernel: ata6: COMRESET failed (errno=-16)
then:
Dec 14 13:39:22 Sextuple kernel: blk_update_request: I/O error, dev sdf, sector 0
Dec 14 13:39:22 Sextuple kernel: blk_update_request: I/O error, dev sdf, sector 9437256
Dec 14 13:39:22 Sextuple kernel: md: super_written gets error=-5, uptodate=0
Dec 14 13:39:22 Sextuple kernel: md/raid:md127: Disk failure on sdf3, disabling device.
Dec 14 13:39:22 Sextuple kernel: md/raid:md127: Operation continuing on 5 devices.
Dec 14 13:39:22 Sextuple kernel: blk_update_request: I/O error, dev sdf, sector 72
Dec 14 13:39:22 Sextuple kernel: md/raid1:md0: Disk failure on sdf1, disabling device.
Dec 14 13:39:22 Sextuple kernel: md/raid1:md0: Operation continuing on 5 devices.
Dec 14 13:39:22 Sextuple kernel: sd 5:0:0:0: [sdf] tag#23 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Dec 14 13:39:22 Sextuple kernel: sd 5:0:0:0: [sdf] tag#23 CDB: Read(10) 28 00 5e 7d 7a 40 00 00 b0 00
Dec 14 13:39:22 Sextuple kernel: blk_update_request: I/O error, dev sdf, sector 1585281600
Dec 14 13:39:22 Sextuple kernel: sd 5:0:0:0: [sdf] tag#3 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Dec 14 13:39:22 Sextuple kernel: sd 5:0:0:0: [sdf] tag#3 CDB: Read(10) 28 00 5e 7d 83 40 00 00 80 00
Dec 14 13:39:22 Sextuple kernel: blk_update_request: I/O error, dev sdf, sector 1585283904
Dec 14 13:39:22 Sextuple kernel: sd 5:0:0:0: [sdf] tag#6 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Dec 14 13:39:22 Sextuple kernel: sd 5:0:0:0: [sdf] tag#6 CDB: Read(10) 28 00 94 3d 88 c0 00 00 40 00
then:
Dec 14 13:50:24 Sextuple kernel: blk_update_request: 13 callbacks suppressed
Dec 14 13:50:24 Sextuple kernel: blk_update_request: I/O error, dev sdf, sector 8388680
Dec 14 13:50:24 Sextuple kernel: md: super_written gets error=-5, uptodate=0
Dec 14 13:50:24 Sextuple kernel: md/raid:md1: Disk failure on sdf2, disabling device.
Dec 14 13:50:24 Sextuple kernel: md/raid:md1: Operation continuing on 5 devices.
lastly
Dec 14 13:58:02 Sextuple kernel: sd 5:0:0:0: [sdf] tag#7 CDB: Read(10) 28 00 e8 e0 88 a8 00 00 08 00
Dec 14 13:58:02 Sextuple kernel: blk_update_request: I/O error, dev sdf, sector 3907029160
Dec 14 13:58:02 Sextuple kernel: Buffer I/O error on dev sdf, logical block 488378645, async page read
So, dead drive, volume showed as "DEGRADED" and a small bit of panic sets in (I have a full cloud AND local RND102 backup of data).
Anyway, got home, removed the drive, and reinsterted/reseated it.
OS6 pickup the drive straight away - it appeared grey and needed a format, so I did
Rebuild starts
12 hours later... everything is rebuilt and back to the way it was... except:
Hard disk temps were -1
system temp was 60+
Frontview still showed a red/white "do not enter" cirlce on disk 6
Couldn't shut down
Couldn't reboot
tried from a terminal, which successfully killed SSH daemon but left the box running.
Frontview still showed "DEGRADED"
Pulled the power cord, and plugged back in.
All is back to normal
2 days of mucking about for absolutely nothing. NOTE: please ensure you have a backup of your data when a ReadyNAS decides to lose a drive.
- bedlam1Prodigy
Preferably before the ReadyNAS decides to lose a drive :smileylol::smileylol:
