DaddyR1
Jun 07, 2014Aspirant
Ultra 6 freezing on boot
I've had the Ultra 6 for a few years, it's worked perfectly, I've not changed the 3 x 2Tb drives that it came with and the only "clever" thing I have done is follow the instructions to enable Transmis...
Jun 07, 2014Guru - Experienced User
The warranty should be 3 years - is it still covered? If so, try email support at support.netgear.com
If you have ssh installed, try logging in and entering
and let us know the results.
df . -h
df . -i
- Jan 17, 2024Retired_Member
