davidr1
Jan 06, 2013Luminary
Ultra II - has it been replaced?
Hi, Does anybody know if the ReadyNas Ultra II is still being made or has it been superceded? A few on-line places have it marked as 'no longer available' - and it seems to have gone up a lot in...
mdgm-ntgr
Jan 08, 2013NETGEAR Employee Retired
Noise should be similar. As the Pro 2 has a faster CPU than the Ultra 2 the CPU would likely be under less load most of the time which might mean some of the time the CPU gives off less heat and hence the fan runs slower which would mean less noise.
Note the Ultra 2 Plus and Pro 2 have the same CPU
