toby11
Oct 16, 2013Aspirant
Ultra2+ not fully visible in Raidar and no Frontview Access
Hi, we are having an Ultra2+ with 2 Drives (Mirror). Data access to the shares is working fine. Pinging the NAS works fine. I recently noticed that I can´t access the NAS by Browser, because Frontvie...
Oct 16, 2013Guru - Experienced User
The ReadyNAS boots up off off the hard drives (from the OS partition). Logs are stored there, along with some add-on data (in particular ReadyDLNA's SQL database). As the OS partition fills up, the NAS starts misbehaving, and eventually will lock up.
toby wrote: ...What does 4GB OS partition mean ? Who do I fix this ?
If you had caught it sooner, you could have deleted the system and backup logs from frontview, and installed an add-on that moves the ReadyDLNA database to the data volume.
Try an on-line support request at support.netgear.com. This is something they can fix remotely pretty easily. You'd need to give them access to the NAS and boot it up in tech support mode.
