gadgetdave
May 21, 2012Aspirant
Ultra4 RMA'd Ultra4+(?), shares don't show - case 18533868
Hi, I've had my Ultra 4 replaced with a RMA due to the following: Unexpected enclosure status detected [NAS] V3_3 power is out of normal range [expected: 3.30 current: 3.07]. Netgear support wa...
mdgm-ntgr
May 21, 2012NETGEAR Employee Retired
What firmware was on the faulty unit?
You can't downgrade from firmware newer than 4.2.15 to 4.2.15 or earlier.
Regardless of the situation it is recommended to use a spare disk (must not be from your array) to update the firmware on a replacement unit to at least as new as what was on the old unit before doing a migration. This should ensure a smooth migration following the FAQ entry you linked to.
