gadgetdave
May 21, 2012Aspirant
Ultra4 RMA'd Ultra4+(?), shares don't show - case 18533868
Hi, I've had my Ultra 4 replaced with a RMA due to the following: Unexpected enclosure status detected [NAS] V3_3 power is out of normal range [expected: 3.30 current: 3.07]. Netgear support wa...
mdgm-ntgr
May 21, 2012NETGEAR Employee Retired
It should work fine (hopefully) after the firmware update. If not, contact support again and they can continue to help resolve the issue on the replacement chassis.
The Pioneer was the name used for the home versions of the long discontinued NVX and Pro systems to distinguish them from the Business Models. Many people found this confusing so NetGear decided to have separate Ultra and Pro lines with the Ultra the follow on to the Pioneer and the Pro the follow on to the Business Edition. The carry on of the Pioneer name with the Ultra series was a bit confusing. You should see it say Ultra 4 (with no mention of Pioneer) like on your old unit after the firmware update, I think. I remember my Ultra 6 confusingly being called in RAIDar a ReadyNAS Ultra 6 Pioneer Edition but that was back in the beta period on much older firmware than 4.2.15.
