gadgetdave
May 21, 2012Aspirant
Ultra4 RMA'd Ultra4+(?), shares don't show - case 18533868
Hi, I've had my Ultra 4 replaced with a RMA due to the following: Unexpected enclosure status detected [NAS] V3_3 power is out of normal range [expected: 3.30 current: 3.07]. Netgear support wa...
mdgm-ntgr
May 21, 2012NETGEAR Employee Retired
gadgetdave wrote:
Put 1 1TB drive in but have had to go into boot menu and do a factory reset, its now formatting the 1TB, hopefully can then do a full update and stick the original drives back in !
Yes, you should be able to. Shouldn't be too long since there's only the one disk installed (no need for a resync to sync drives sector by sector).
gadgetdave wrote:
Then first order of business - backup :)
Good plan. Might want to have a read of Preventing Catastrophic Data Loss
gadgetdave wrote:
Cheers again, will report back later!
Time for me to get some sleep.
