keenan1
Dec 09, 2011Aspirant
Unable to access the data volume after disk replacement
Summary: After a hard drive failure and hot-swap, all volumes have disappeared. I'm not sure but believe this was caused by some Smart Errors on a second drive while the replacement drive was being ...
PapaBear1
Dec 10, 2011Apprentice
Kudos on the backup. Although at times a major PITA to do, and another one if you have to recover your data from the backup, but at least you will have data to recover. This situation, hopefully will be resolved by tech support, but in case it doesn't, this is the reason we promote the creation and maintenance of a backup.
