Hightower
Jan 05, 2017Aspirant
unable to connect to admin page. rest is working normal
I am unable to connect to the administration page. Nothing have been changed since long time. Shares are accessible in windows, Android and media players. Website is running normal. It is given always...
- Jan 09, 2017
After some attempts to find a 2nd reason why it was not accessible. And I was unable to read or copy the error file (did not know how). I decided to reinstall the os. That did not change anything. So I cleared the whole system. And now I am putting the backup back.
Everything is now almost back as normal.
So problem solved but not the way I would like.
If my knowledge of telnet was as good as good old DOS I would investigate longer and would find and fix the problem. But telnet is way out of my comfort zone.
Thanks for your attempts to help me find the problem.
Hightower
Ohh sorry for not putting it on I forgot
It's a readynas duo v1. With 2 x 2tb disc
It has I think the last version of its firmware.
Apps standard plus owncloud. And some apps to see the status on a android app. Don't know the names ans can not see it anymore
Edit addded
I backed up all data and this forum is my last resort before I preform a factory reset. But I am a bit afraid that the administration page remains unavailable after the reset. And only the administration page is unavailable the rest is working fine atm.
Jan 05, 2017Guru - Experienced User
It could be a full OS partition - the v1 only has 2 GB for that.
Is SSH enabled (and if so does it connect?)
