Hightower
Jan 05, 2017Aspirant
unable to connect to admin page. rest is working normal
I am unable to connect to the administration page. Nothing have been changed since long time. Shares are accessible in windows, Android and media players. Website is running normal. It is given always...
- Jan 09, 2017
After some attempts to find a 2nd reason why it was not accessible. And I was unable to read or copy the error file (did not know how). I decided to reinstall the os. That did not change anything. So I cleared the whole system. And now I am putting the backup back.
Everything is now almost back as normal.
So problem solved but not the way I would like.
If my knowledge of telnet was as good as good old DOS I would investigate longer and would find and fix the problem. But telnet is way out of my comfort zone.
Thanks for your attempts to help me find the problem.
Hightower
SSH enabled for the Nas utils app.
Failed to connect to /192.168.2.1 (port 22): connecttion refused)
Connect failed: ECONNREFUSED (Connection refused)
Jan 05, 2017Guru - Experienced User
Options are
(a) boot in tech support mode, and telnet into the box. You'd need to manually mount the OS partition. There's some info here: https://community.netgear.com/t5/Using-your-ReadyNAS/Readynas-NV-V1-Mounting-OS-partition-in-support-mode/td-p/894479
(b) Try an OS reinstall, and if that fails go right to the factory reset.
