Hightower
Jan 05, 2017Aspirant
unable to connect to admin page. rest is working normal
I am unable to connect to the administration page. Nothing have been changed since long time. Shares are accessible in windows, Android and media players. Website is running normal. It is given always...
- Jan 09, 2017
After some attempts to find a 2nd reason why it was not accessible. And I was unable to read or copy the error file (did not know how). I decided to reinstall the os. That did not change anything. So I cleared the whole system. And now I am putting the backup back.
Everything is now almost back as normal.
So problem solved but not the way I would like.
If my knowledge of telnet was as good as good old DOS I would investigate longer and would find and fix the problem. But telnet is way out of my comfort zone.
Thanks for your attempts to help me find the problem.
Hightower
Jan 06, 2017Aspirant
connected to the telnet mode od the readynas duo v1,
but all other commands in the link given are not working.
wich directory are the supposed problem giving log files
Jan 06, 2017Guru - Experienced User
Did you get an error when you entered start_raid.sh ?
Log files are in /var/log, but you can't see that unless you can start raid and then mount the OS partition.
