danesol
Feb 15, 2022Aspirant
Unable to connect using a browser
All of a sudden when I try and access either the admin page or my own share, i get this message using EDGE or Google Chrome; This site can’t provide a secure connection 192.168.0.10 uses an unsu...
Feb 15, 2022Guru - Experienced User
danesol wrote:
>I'm playing about with creating Certificates now to see if I can get round this issue that way
That won't work - it's not about the certificate, it's about the lack of support for TLS 1.2 in the NAS.
danesol
Strangely though when I access the default shares ( 192.168.0.10/shares ) it loads both in Edge and Google Chrome Why does that work ???
- StephenBFeb 15, 2022Guru - Experienced User
danesol wrote:
Strangely though when I access the default shares ( 192.168.0.10/shares ) it loads both in Edge and Google Chrome Why does that work ???That is connecting with http, not https. Since there is no encryption with http, TLS isn't being used.
The NAS is redirecting http to https when you connect to frontview, so at present you cannot work around the issue by explicitly browsing to http://nas-ip-address/admin. It looks like it is possible to eliminate the redirection by changing two configuration files in the NAS - something on my list to try, but I haven't gotten to it yet.
