danesol
Feb 15, 2022Aspirant
Unable to connect using a browser
All of a sudden when I try and access either the admin page or my own share, i get this message using EDGE or Google Chrome; This site can’t provide a secure connection 192.168.0.10 uses an unsu...
jjcf89_2
Mar 14, 2022Tutor
StephenB wrote:
jjcf89_2 wrote:If I can unbrick my unit, I might just go with the remove the http redirect approach
An OS reinstall should restore the broken library (and change your admin password back to netgear1).
I couldn't test the change to virtual.conf for 4.2.x systems (as I no longer am running 4.2.x). It's be useful to know if it also works with 4.2.x. I suspect it will, but there might be some other changes needed in httpd.conf.
Okay that sounds promising, I wasn't sure how much of the files would be restored by the OS reinstall.
I'm familiar with apache configs, I can take a look assuming I get back to it.
jjcf89_2
Mar 15, 2022Tutor
To update:
The os reinstall did not work. The system hung on the "Booting ..." screen like before.
However now when I try to chroot in tech support mode, I get a malloc error.
# chroot /sysroot
malloc: unknown:0: assertion botched
free: called with already freed block argument
last command: (null)
Aborting...Aborted- StephenBMar 15, 2022Guru - Experienced User
Ouch. Not something I expected, with only the one library being updated in the add-on.
Can you run commands directly from sysroot? For example,
# /sysroot/bin/df . -h
- jjcf89_2Mar 15, 2022Tutor
Rusty posted fixed deb files. Which got my system back up and running. https://github.com/rdynsxtrs/rn4bin/issues/3
- SandsharkMar 16, 2022Sensei
I installed the new package on a freshly factory defaulted Pro2 running 4.2.31. Though, after an inordinately long period of time, it ultimately reported an error in the installation, it works.
