binglee_eg
Nov 16, 2011Aspirant
Unable to mount disk from ReadyNas NV+
Hi I've read the support and forums to try get data back from a ReadyNAS NV+ with RAIDar 3.x(?) but am running into mount problems. ReadyNAV NV+ symptoms: very slow to boot, came up with a sync ...
mdgm-ntgr
Nov 16, 2011NETGEAR Employee Retired
Rather than try to recover data like that if you suspect a bad disk you should first test the disks: http://www.readynas.com/kb/faq/hardware/how_can_i_verify_that_my_disk_is_bad
