binglee_eg
Nov 16, 2011Aspirant
Unable to mount disk from ReadyNas NV+
Hi I've read the support and forums to try get data back from a ReadyNAS NV+ with RAIDar 3.x(?) but am running into mount problems. ReadyNAV NV+ symptoms: very slow to boot, came up with a sync ...
binglee_eg
Nov 17, 2011Aspirant
Update:
Apart from the edit I made above, I stuck in a new disk to test. It booted and runs and sees the single disk, but when I go to volumes there is no tab for Volumes, just USB. Can't I have a single disk, or is this something more problematic? Should I do TFTP firmware refresh (and will that destroy the original disks when I put them back into the NAS?)
