binglee_eg
Nov 16, 2011Aspirant
Unable to mount disk from ReadyNas NV+
Hi I've read the support and forums to try get data back from a ReadyNAS NV+ with RAIDar 3.x(?) but am running into mount problems. ReadyNAV NV+ symptoms: very slow to boot, came up with a sync ...
binglee_eg
Nov 20, 2011Aspirant
did a full factory reset, and it worked with a new disk. Not sure if the firmware needs a reflash with the TFTP yet though.
Did a disk test with the the first set of disks of the RAID, and they were ok. Plugged it back into the linux box, and suddenly I could mount it. So I've got the data from the first set of the RAID. The second raid disk is still giving errors on the pvscan though.
