bedwardsnexlear
Feb 27, 2012Aspirant
Unable to save permission changes ... parameter is incorrect
ReadyNAS Pro 4 RAIDiator 4.2.19 I have a share that has been working perfectly for months, since it's creation. I have had no issues adding or removing users from the share via \\readynas-name\c u...
ReadySECURE
Feb 27, 2012Apprentice
bedwardsnexlearn
Have you tried the process of leaving and rejoining the domain? Sometimes this will fix the issue. If that does not work; then you may want to try exporting and importing the domain ID map. Also, do you have multiple Domain Controllers on the network? If you do, did you specify the IP address of this Domain Controller when you were joining the domain?
