bedwardsnexlear
Feb 27, 2012Aspirant
Unable to save permission changes ... parameter is incorrect
ReadyNAS Pro 4 RAIDiator 4.2.19 I have a share that has been working perfectly for months, since it's creation. I have had no issues adding or removing users from the share via \\readynas-name\c u...
ReadySECURE
Feb 28, 2012Apprentice
bedwardsnexlearn
Go into the share listing, select the share's CIFS, then select advanced. Change the owner information to "nobody" and "nogroup". Make sure to check the box below that states that it will set the share options to the above information; then apply. When you apply, it will act as though it didn't change. Don't worry, it did. Then you will want to go and disable, then re-enable CIFS under Services > Standard File Protocols. After that is all said and done, give it another try. These steps may interfere with production. So to be sure that you aren't interrupting someone or something; you may want to schedule downtime or do this after hours.
