mike_coreit
Mar 18, 2020Aspirant
Unsecure connection
Hi, after I log on to https://readycloud.netgear.com the address bar shows that the page is unsecure. Has anyone else noticed this? I have tried different browsers (Firefox and Edge), also I have tr...
JohnCM_S
Mar 18, 2020NETGEAR Employee Retired
Hi mike_coreit,
The ReadyCLOUD portal actually runs on HTTPS.
The reason that you see HTTP when you login into the portal is for our home routers where they also connect to ReadyCloud however due to their specifications they usually are having a hard time maintaining HTTPS connection due to certificates being updated from time to time. So seeing the portal on HTTP is just actually for the routers to be able to use its feature but ensuring back-end and other access is secured using HTTPS and VPN connections.
- May 21, 2023Retired_Member
