BotanyBay
Oct 25, 2017Tutor
Update from 6.7.5 to 6.9.0 not rebooting or shutting down
Just updated a new (currently not production) 626 from 6.7.5 to 6.9.0 and after using the web application to upload the firmware the unit requested permission to reboot "Firmware version 6.9.0 was up...
mdgm-ntgr
Oct 25, 2017NETGEAR Employee Retired
Strange. Did you try pressing the power button briefly three times to shutdown the unit?
BotanyBay
Oct 26, 2017Tutor
mdgm wrote:Strange. Did you try pressing the power button briefly three times to shutdown the unit?
Not yet, was checking to see if anyone wanted me to look around the unit before I did anything more drastic.
My plan is to try the graceful shutdown via the power switch (press power button 3 times)
If that does not work, hold the power button until the machine powers off and then power back on
If that does not work, pull the plug
As of this morning it still had the "Rebooting, See you soon..." on the front panel.
I'll report back with the result and what the status of the box is after these attempts.
David
- BotanyBayOct 26, 2017Tutor
Three presses of power switch resulted in the front panel stuck at "shutting down goodby" and not being able to get in at the web interface.
Forced power cycle did result in the firmware update being applied.
However, if I go into the web interface and issue a shutdown command it gets stuck at "Powering Off, Goodby"
Power cycling the unit manually does recover operation.
I have not installed any apps on this unit, it is a "fresh out of the box" install. The only thing which has been done to it is enabling SSH.
- mdgm-ntgrOct 27, 2017NETGEAR Employee Retired
Have you reviewed the logs around the reboot times looking for clues?
How full is the 4GB root volume?
