TheCritic
Mar 02, 2012Aspirant
Updated to 4.2.19, doesn't come up?
Updated my Ultra 2 from I believe .15 to .19 last night, did a reboot. Still wasn't back on network 12 hours later. Rebooted again, saw it briefly in raidiator (blue dot) but it then went back offline...
mdgm-ntgr
Mar 02, 2012NETGEAR Employee Retired
There is a problem with directly updating from that firmware to 4.2.19 (this issue has been solved in 4.2.20).
Here's a good solution if you have a spare disk (must not be from your array): http://www.readynas.com/forum/viewtopic.php?p=340135#p340135
If you don't have a spare disk, contact tech support (http://www.readynas.com/support). They should be able to downgrade the firmware for you so you can get the unit back into a working state.
