TheCritic
Mar 02, 2012Aspirant
Updated to 4.2.19, doesn't come up?
Updated my Ultra 2 from I believe .15 to .19 last night, did a reboot. Still wasn't back on network 12 hours later. Rebooted again, saw it briefly in raidiator (blue dot) but it then went back offline...
TheCritic
Thank you, Thank You!, THANK YOU!!!
I'd noticed the upgrade through frontview didn't work--but it did not display any warning either--didn't think much of it, READ THE RELEASE NOTES, downloaded and did the deed. Which killed it dead.
So per your advice I put in a drive that was sitting around, came up (yay!) as corrupted root, did the reset to factory defaults secret handshake, put on .17, once it was happy put my disks back in and it was happily running .17 (with all my settings intact), upgraded to .19 and all is well.
So again, THANK YOU! But why the hell didn't Netgear pull this or make note of the problem?
