ckelly33
Dec 03, 2013Aspirant
Updating firmware...FOREVER
I decided to upgrade my NAS's firmware and I usually do it manually, so I downloaded it. The version I downloaded was RAIDiator 4.1.13 (Sparc) but my ReadyNAS Duo (v1) didn't like it so I decided to try to let the NAS check for new firmware via the remote option. It came back with a slightly different 4.1.12 so I chose to let it upgrade. It rebooted and RAIDar says it is updating - but it has been updating for 2-3 hours now. I've never done a 'automatic update", I've always done it manually and it has taken MAYBE 20 minutes. Currently, the blue power light is flashing regularly about once a second and the little green LED below it (looks like it is labeled ACT or DCT?)will flash once every fourth time that the blue light lights up.
I closed RAIDar and reopened it and it still says updating but nothing has changed for hours. I have thought about unplugging it and powering back up but I am afraid that will brick it if it is truly updating. Any suggestions or experience with this?
BTW, one of my drives was going bad, I'm not sure if one has anything to do with the other. Not sure which one it was.
Thanks for any help!
- StephenBGuru - Experienced UserAll you needed to do with a new disk was insert it, and then power up. The NAS will automatically do a factory install on an empty disk.
Either way, there is a delay (about 10 minutes) before the install starts, to give you a chance to choose xraid or flexraid with RAIDar. What is RAIDar telling you now?
