sshirley
Oct 03, 2016Aspirant
Updating RN104 Firmware
Hi everyone, My ReadyNAS 104 is current on firmware version 6.2.0 and I've been trying to update it to the latest version. All attempts at using the web client have failed (either through the aut...
- Oct 04, 2016
This was solved by MGDM. It seems 6.2.5 was on the flash but 6.2.0 was on the disks. Thanks!
Oct 03, 2016Guru - Experienced User
Per the release notes: RN102 & RN104 systems running firmware older than 6.2.1 should first update to 6.2.5, then update from 6.2.5 to 6.6.0.
mdgm-ntgr
Oct 03, 2016NETGEAR Employee Retired
After updating to 6.2.5 you will then need to use this workaround to update the firmware. This is needed just for the update from 6.2.5. Future updates would then be done the normal way.
