benoitx
Sep 15, 2011Aspirant
Upgrade disks and SECURE erase?
HI * I have a few posts about this but I want to confirm a couple of basic points for my ReadyNAS Duo (2 x 1TB RAID). 1) I'd like to upgrade the disks to 2TB, I believe it is the maximum for Rea...
dannas1
Sep 16, 2011Tutor
Use DBAN (just google it for website and download) which will wipe can do differnet types of wipes on hhd's, it comes as a self booting app, to be on the safe side before using it i would deconnect your pc drives (c:/ etc), as im not sure if it will wipe everything it can see or if you get options.
Wiping with it can take hours, as it will do more than one pass on your disks (i think that options range from 1 to 7 passes).
