benoitx
Sep 15, 2011Aspirant
Upgrade disks and SECURE erase?
HI * I have a few posts about this but I want to confirm a couple of basic points for my ReadyNAS Duo (2 x 1TB RAID). 1) I'd like to upgrade the disks to 2TB, I believe it is the maximum for Rea...
benoitx
Sep 17, 2011Aspirant
Thank you for the postings.
My main laptop is a Mac but I also have a PC.
So, since there are no comments on the upgrade method from 1TB to 2TB, I assume that it is the correct way.
The only remaining question is whether a product like DBan or any other secure disk eraser would work 'remotely'... and that means that I would have to replug the 2 1TB disks in the Duo in order to do this? However long that takes...
Correct?
Many thanks
Benoit
Correct?
Many thanks
Benoit
