scottonaharley
Nov 13, 2017Aspirant
upgrade from 6.8.1 to 6.9 disabled eth0,1,2,3
I upgraded my readynas 4220 from 6.8.1 to 6.9.0 and the three onboard ethernet ports are showing DHCP enabled in the gui but do not link to the switch. It seems as if they are administrativly disabl...
- Nov 20, 2017
No the interfaces were not bonded.
I was able to solve the problem by executing the following steps:
1) enable ssh access
2) login and su to root
3) ifconfig <interface> down (for each non-functioning interface)
4) restart
5) went directly to ssh before opening Frontview
6) login and su to root
7) ifconfig <interface> up (for each non-functioning interface)
Interface links came up and bi directional data flow started.
8)Frontview correctly displayed the link status and was able to control the links where as before the links stayed down in spite of enabling them in Frontview.
I'm not sure why this worked. A factory reset should have worked as I would think that at first boot after the reset the hardware would be scanned. Without studying the inner workings of frontview its hard to say if it was an O.S. issue, Frontview issue or combination.
We can mark this as problem solved but root cause unknown.
Marc_V
Nov 20, 2017NETGEAR Employee Retired
Hi scottonaharley!
We had issues reported on ReadyNAS models regarding Network interfaces getting disabled an/or reset after the update.
Were your Eth ports configured as a bond? You may want to check on the Beta FW ReadyNASOS 6.9.1-T129 Beta 2.
Please let us know if this helped.
Marc
NETGEAR Community Team
scottonaharley
Nov 20, 2017Aspirant
4) restart
