alverton
Aug 14, 2018Aspirant
Upgrade from OS4 to OS 6 Ultra 4 plus
Hi, can someone help me with the two files that are needed to perform this upgrade from OS4 to OS6 as Netgear appears to have removed them from the website.
Many thanks if you can help me.
- Retired_MemberAug 14, 2018
Hi alverton, if I understand correctly @StephenB provided a solution for this with links, which are now pointing into nowhere.
Let us ask him, whether he still has the files and could provide them to you or whether he might know where the data has been moved to or last but not least whether NETGEAR had a good reason for removing the information.
Retired_Member
Aug 14, 2018Hi alverton, if I understand correctly @StephenB provided a solution for this with links, which are now pointing into nowhere.
- StephenBAug 14, 2018Guru - Experienced User
The binaries aren't mine, my links were pointing to Netgear's repository.
However, I do have the current files, and I'll PM alverton with links to my copies.
- Retired_MemberAug 16, 2018
I would love to kudo your feedback, dear StephenB, but the system does not let me. Reported this already in the community feedback realm some time ago, but no change so far.
https://community.netgear.com/t5/Community-Feedback/Would-like-to-kudo-but-can-not/m-p/1610065#M452
- dccastilAug 20, 2018Aspirant
Hi StephenB
I have an Ultra 4 plus and am trying to migrate to OS6 as well, but as we know the links for the firmware are broken. Would you be willing to PM them to me? Would be ever so grateful as I cannot access the device in ReadyCloud as I am still on FW 4.2.31. Thanks in advance for your reply.
- mdgm-ntgrAug 21, 2018NETGEAR Employee Retired
Sent you links to the files.
- alvertonAug 15, 2018Aspirant
Worked perfectly - made be very happy, Thank you.
