danioj
Jan 11, 2013Aspirant
Upgrade Nv+ with WD 2TB HDD's
Hello All, It has been sometime since I have posted on the forum - years I think. Testament to the quality of the Readynas product really, given I signed up initially for support. I have had an ...
danioj
Thanks for the quick reply mdgm. Happy to follow your advice with drive selection. Below are the contents of my partion.log just extracted:
Disk /dev/hdg doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 3906992335 1951192152 5 Extended
/dev/hdc5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
/dev/hde1 32 4096031 2048000 83 Linux
/dev/hde2 4096032 4608031 256000 82 Linux swap / Solaris
/dev/hde3 4608032 3906992335 1951192152 5 Extended
/dev/hde5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
Starting to get out of my depth now, but hope you know what all that means. I appreciate the help.
