confused_wookie
Apr 25, 2013Follower
Upgrade ReadyNAS Duo v2 firmware > 5.3.7
Hello, I have recently attempted a firmware upgrade on my ReadyNAS Duo v2 from 5.3.4 to 5.3.7 using the webconsole. I have run into a problem during the reboot part of the upgrade. After the first...
chirpa
May 07, 2013Luminary
If you haven't already resolved it (this post is 2+ weeks old), can you hard power cycle it (turn it completely off, back on again)? It may have 'borked' during a uboot update (boot loader).
Cloud, you are a NTGR support person, can you try and fix it without them going through the suffering of trying to go through the support loop?
