realtek1
May 24, 2017Apprentice
Upgrade to 6.7.3 failed
Hi, I was on ReadyNAS 6.7.1 and I tried to upgrade today to 6.7.3 and the upgrade failed and now I am stuck. Any idea's? I managed to get all the log files off the device (I have a ReadyNAS 5...
jak0lantash
May 24, 2017Mentor
If you want to check the logs since the last boot, look at systemd-journal.log and search for the last instance of "jenkins@blocks". Search for clues from there.
You may also check in initrd.log if there is any error related to the firmware update.
realtek1
Hi,
Thanks for your quick reply, here is the latest boot which looks like the issue to me, although I could be wrong:
May 24 21:00:53 NAS leafp2p[5656]: Parsing config
May 24 21:00:53 NAS leafp2p[5656]: Access rules valid 1
May 24 21:00:53 NAS leafp2p[5656]: Service valid replication 1
May 24 21:00:53 NAS leafp2p[5656]: service replication ReadyNAS Replication 1 1 0
May 24 21:00:53 NAS leafp2p[5656]: Service valid remote 1
May 24 21:00:53 NAS leafp2p[5656]: service remote ReadyNAS Remote 0 1 0
May 24 21:00:53 NAS leafp2p[5656]: Service config valid 1
May 24 21:00:53 NAS leafp2p[5656]: Applying firewall 0
May 24 21:00:53 NAS leafp2p[5656]: Applying rescan devices 1
May 24 21:00:53 NAS leafp2p[5656]: Applying connection method type 0
May 24 21:00:53 NAS leafp2p[5656]: Applying connection try mask 0
May 24 21:00:53 NAS leafp2p[5656]: Running as multipresence-compatible server.
May 24 21:00:53 NAS leafp2p[5656]: Applying peer route type 1
May 24 21:00:53 NAS leafp2p[5656]: P2P username: nas-E6-E9-8C_WyTnB_E8FCAFE6E98C
May 24 21:00:53 NAS leafp2p[5656]: url https://peernetwork.netgear.com:443//peernetwork/services/LeafNetsConfigWebService
May 24 21:00:53 NAS leafp2p[5656]: SOAP 1.1 fault: SOAP-ENV:Client [no subcode]
May 24 21:00:53 NAS leafp2p[5656]: "Name or service not known"
May 24 21:00:53 NAS leafp2p[5656]: Detail: getaddrinfo failed in tcp_connect()
May 24 21:00:53 NAS leafp2p[5656]: Error configuring peer network
May 24 21:00:53 NAS leafp2p[5656]: Error configuring network -1
May 24 21:00:53 NAS leafp2p[5656]: Cleanup web service
May 24 21:00:53 NAS leafp2p[5656]: Cleanup params
May 24 21:00:53 NAS leafp2p[5656]: Error logging in
May 24 21:00:53 NAS leafp2p[5656]: Error starting application -6
May 24 21:00:53 NAS leafp2p[5656]: Start state -1
- jak0lantashMay 24, 2017Mentor
Nah, leafp2p is related to the Cloud services. So that's not your issue.
- realtek1May 24, 2017Apprentice
ok thanks, Is it possible to use the USB Recovery Tool on the RN 526X ? There is no backup button so would I keep the reset button held in on the back after inserting the USB?
Thanks
- mdgm-ntgrMay 24, 2017NETGEAR Employee Retired
Can you send in the logs (see the Sending Logs link in my sig)?
