realtek1
May 24, 2017Apprentice
Upgrade to 6.7.3 failed
Hi, I was on ReadyNAS 6.7.1 and I tried to upgrade today to 6.7.3 and the upgrade failed and now I am stuck. Any idea's? I managed to get all the log files off the device (I have a ReadyNAS 5...
realtek1
Hi,
Thanks for your quick reply, here is the latest boot which looks like the issue to me, although I could be wrong:
May 24 21:00:53 NAS leafp2p[5656]: Parsing config
May 24 21:00:53 NAS leafp2p[5656]: Access rules valid 1
May 24 21:00:53 NAS leafp2p[5656]: Service valid replication 1
May 24 21:00:53 NAS leafp2p[5656]: service replication ReadyNAS Replication 1 1 0
May 24 21:00:53 NAS leafp2p[5656]: Service valid remote 1
May 24 21:00:53 NAS leafp2p[5656]: service remote ReadyNAS Remote 0 1 0
May 24 21:00:53 NAS leafp2p[5656]: Service config valid 1
May 24 21:00:53 NAS leafp2p[5656]: Applying firewall 0
May 24 21:00:53 NAS leafp2p[5656]: Applying rescan devices 1
May 24 21:00:53 NAS leafp2p[5656]: Applying connection method type 0
May 24 21:00:53 NAS leafp2p[5656]: Applying connection try mask 0
May 24 21:00:53 NAS leafp2p[5656]: Running as multipresence-compatible server.
May 24 21:00:53 NAS leafp2p[5656]: Applying peer route type 1
May 24 21:00:53 NAS leafp2p[5656]: P2P username: nas-E6-E9-8C_WyTnB_E8FCAFE6E98C
May 24 21:00:53 NAS leafp2p[5656]: url https://peernetwork.netgear.com:443//peernetwork/services/LeafNetsConfigWebService
May 24 21:00:53 NAS leafp2p[5656]: SOAP 1.1 fault: SOAP-ENV:Client [no subcode]
May 24 21:00:53 NAS leafp2p[5656]: "Name or service not known"
May 24 21:00:53 NAS leafp2p[5656]: Detail: getaddrinfo failed in tcp_connect()
May 24 21:00:53 NAS leafp2p[5656]: Error configuring peer network
May 24 21:00:53 NAS leafp2p[5656]: Error configuring network -1
May 24 21:00:53 NAS leafp2p[5656]: Cleanup web service
May 24 21:00:53 NAS leafp2p[5656]: Cleanup params
May 24 21:00:53 NAS leafp2p[5656]: Error logging in
May 24 21:00:53 NAS leafp2p[5656]: Error starting application -6
May 24 21:00:53 NAS leafp2p[5656]: Start state -1
jak0lantash
May 24, 2017Mentor
Nah, leafp2p is related to the Cloud services. So that's not your issue.
- realtek1May 24, 2017Apprentice
ok thanks, Is it possible to use the USB Recovery Tool on the RN 526X ? There is no backup button so would I keep the reset button held in on the back after inserting the USB?
Thanks
- mdgm-ntgrMay 24, 2017NETGEAR Employee Retired
Can you send in the logs (see the Sending Logs link in my sig)?
- jak0lantashMay 24, 2017Mentor
If you can get to the point to download the logs, USB Boot Recovery is not the right step.
