realtek1
May 24, 2017Apprentice
Upgrade to 6.7.3 failed
Hi, I was on ReadyNAS 6.7.1 and I tried to upgrade today to 6.7.3 and the upgrade failed and now I am stuck. Any idea's? I managed to get all the log files off the device (I have a ReadyNAS 5...
realtek1
May 26, 2017Apprentice
Hi,
After looking at a lot of the log files, Is it possible to issue is related to the transmission app?
I have a lot of errors about it and also about upgrading the sqldb related to transmission.
Also, there are a lot of transmission segfault's.
Whats the best way to manually remove the app? Can I just delete the folder from the apps directory? For now I have tried removing the service reference from the config.xml in the hope it won't try and start it.
Thanks
mdgm-ntgr
May 26, 2017NETGEAR Employee Retired
Please update to ReadyNAS OS 6.7.4 which is now available!
To do this you might need to do USB Boot Recovery.
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
