Steve_46's avatar
Steve_46
Upgrade to Ultra 4 Plus, Max storage capacity
I currently have the Ultra 2 Plus with two 2TB Hitachi HDD's and am happy to report that with the help of the excellent support I received from this forum I have it running without issue. I am considering an upgrade to the Ultra 4 Plus and have the following questions:
1. If I were to load up the Ultra 4 Plus with four 2TB HDD's and use the X-RAID configuration for redundant backup, what is going to be my maximum actual storage capacity? I'm assuming it is going to be 4TB but wanted to confirm. Also, is there another RAID type that would allow for higher storage capacity than 4TB using four 2TB drives (while still maintaining a high level of data security) or would I just need to get higher capacity hard drives?
2. I am going to backup all data and remove the two HDD's I have in the Ultra 2 Plus and install these drives into the Ultra 4 Plus to start. During the initial setup of the Ultra 4 Plus will it need to re-format the drives thereby erasing all data or is there a way to set up the X-RAID without erasing the data on the HDD's?
3. Regarding future expansion, when I am ready to add two more HDD's to the Ultra 4 Plus do they have to be the exact same model of Hitachi HDD's?
4. Finally can someone offer any thoughts on the "Link Aggregation" feature using the two ethernet ports. Does this improve performance in a home use environment? Any other thoughts or tips relating to upgrading to a higher capacity NAS are appreciated.
Thank you in advance for everyone's input and help!
  • StephenB's avatar
    Steve 46 wrote:
    I also see a share created for Steve_C (that is my user name) even though there is no Steve_C share in the share listing in Frontview
    The NAS creates a private share for each user. It doesn't show up in Frontview (which in m view is a mistake, as the admin should be able to manage all shares.)
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Not a mistake IMO.
    You can go to Security > User & Group Accounts > Preferences and enable/disable private home shares. Private home shares are accessible by the user and the "admin" (Frontview) user only.
  • StephenB's avatar
    mdgm wrote:
    Not a mistake IMO.
    I only use the built-in admin account. I cannot see the admin home share from FrontView at all, I can only access it from windows explorer.
    So if I used it, I wouldn't be able to fix up permissions, etc. via Frontview. That is what I think is a mistake.
  • mdgm, thanks for the tip on disabling the private share.
    StephenB, As a side note and in question to you saying you only use the built in admin account, I remember that when I first got the Ultra 2 Plus I posted a question about the "C" share being created and if I was supposed to save files to that or to the shares that I created and also how to not see it in Finder when I connect to the NAS. mdgm informed me that the "C" share was where the NAS actually stores the files and that it is visible in Finder when I log in under "admin", that I should save my files to the shares I created, and that I should create myself as a non-admin user (which I did as Steve_C) so I wouldn't see the "C" share anymore. Anyway, my point is that I thought I read somewhere that if you log in as admin and make changes to files, etc. that it could create permission issues for those not logging in as admin and who have access to the same files. I know I'm being vague but it was just a fleeting memory of something that I read. Is there any validation to this?
    Also, one other question. I use an Airport Extreme router and have given my new Ultra 4 Plus an IP address DHCP Reservation based on the Ultra 4's MAC address. I also set the static IP address in Frontview>Network>Interfaces> Use values below. Should I leave the IPv4 assignment set to "Use values from a DHCP server" and just let the Airport Extreme hand out the same DHCP Reserved IP address? It's working the way I have it setup now but I just wanted to make sure if this is the best way.
    Thank you!
  • StephenB's avatar
    I think whenever you have multiple users with write access to a folder, you have the potential to create permissions and ownership issues. There are ACL settings for the share which can prevent these issues, and also the "advanced options" tool to reset owner, group, and access rights. Of course, since I only access it with the admin account, I shouldn't run into those multi-user issues. Though I have needed the "advanced options" tool occasionally. Note I don't normally "C" directly (unless I am moving a lot of data between folders).
    The best way is to have the Ultra set to "user values from a DHCP server" and have the router reserve the IP. Then if you swap out your router later on (or change your IP address scheme) you won't accidentally lose access to the Ultra.
ProSupport for Business
