Supertramp11
Jun 22, 2016Luminary
Upgraded PRO 6 to 6.5.1, had fan problems, went back to 6.5.0 and all is well again
Hi, After having succesfully used 6.5.0 on my PRO 6 since the day it came out, I upgraded to 6.5.1 today. The system fan started to act weird. When putting the fans on COOL, it took a little whi...
anubis1
Jul 27, 2016Aspirant
I am in need of some help with my Pro 6. I've upgraded from 4.2.28 to 6.5.1 without any issues other than my CPU fan reporting as 0rpm as I have moved the fan to the additional system fan header. I've managed to find some topics on how to fix it, however if I then label the 'System' fan as 'CPU' my fan will run at it's max speed no matter what setting I have it on. Whereas my system fan barely raises it's speed no matter the setting or how hot the sensor is reading.
Am I better off just leaving them both labled as system fans or will this cause other issues with them not spinning at the correct RPMs???
I've also just rolled back to version 6.5.0 and I'm still seeing the same issue.
below is a copy of my /etc/sensors.d/system.conf
chip "coretemp-isa-0000"
label temp2 "CPU"
ignore temp3
ignore fan2
chip "w83627dhg-isa-*"
label in1 "DDB18"
set in1_min 1.62
set in1_max 1.98
label in2 "AVCC"
set in2_min 3.3 * 0.90
set in2_max 3.3 * 1.10
label in3 VCC3
set in3_min 3.3 * 0.90
set in3_max 3.3 * 1.10
label in4 VCC1_25
set in4_min 1.17
set in4_max 1.32
label in5 "VCC1_5"
set in5_min 1.41
set in5_max 1.58
label in6 "VCC1_05"
set in6_min 0.98
set in6_max 1.10
set in7_min 3.3 * 0.90
set in7_max 3.3 * 1.10
set in8_min 3.0 * 0.90
set in8_max 3.3 * 1.10
label fan1 "System"
set fan1_min 600
label fan2 "System"
set fan2_min 600
label fan3 "CPU"
set fan3_min 150
ignore fan4
ignore fan5
label temp1 "System"
set temp1_max 80
ignore temp2
ignore temp3
ignore cpu0_vid
ignore intrusion0
ignore fan2
Marsianin
Jul 28, 2016Aspirant
Same problem with "Fan System in enclosure Internal speed is below threshold. (458 rpm)" on Pro 6 with 6.5.1 (but as I remember 6.5.0 has same problem).
