Supertramp11
Jun 22, 2016Luminary
Upgraded PRO 6 to 6.5.1, had fan problems, went back to 6.5.0 and all is well again
Hi, After having succesfully used 6.5.0 on my PRO 6 since the day it came out, I upgraded to 6.5.1 today. The system fan started to act weird. When putting the fans on COOL, it took a little whi...
Marsianin
Jul 28, 2016Aspirant
As for me there is no difference between 6.5.0 and 6.5.1
mdgm-ntgr
Jul 28, 2016NETGEAR Employee Retired
Would be better to get logs on firmware where you are running into the problem. Logs on a firmware where you are not having issues are of little value.
- anubis1Jul 29, 2016Aspirant
I'm having issues in both builds. If I run the CPU fan off the CPU fan header it will run at maximum speed. If I put it on the spare system fan header it will either run slow and not spin up when the CPU gets hot or fluctuate wildly. If I edit /etc/sensors.d/system.conf as I have shown on the previous page with fan3 labled as 'CPU' it will run it at maximum speed again.
At the moment it seems to have settled down somewhat but I cannot be sure it will stay that way,
- JanHussaarts2Aug 01, 2016Luminary
I installed the latest beta (652 T486).
It had the fan issue.
Started the recovery to factory settings.
Still has the fan issue.
- mdgm-ntgrAug 03, 2016NETGEAR Employee Retired
Thanks for checking and letting us know that you still see the issue on 6.5.2 Beta.
- matmercySep 28, 2016Guide
Hi mdgm,
i'm having the same problem on my readynas pro business running OS 6.5.2 "Fan System in enclosure Internal speed is below threshold. (340 rpm)." i will collect the logs and send them.
- mdgm-ntgrSep 28, 2016NETGEAR Employee Retired
We didn't fix this in 6.5.2.
You can try the workaround to override the minimum fan speed.
6.6.0 does have a possible fix for this and will be available soon.- matmercySep 29, 2016Guide
Hi mdgm,
the workaround to override the minimum fan speed worked for me
thanx for your help. :)
