Supertramp11
Jun 22, 2016Luminary
Upgraded PRO 6 to 6.5.1, had fan problems, went back to 6.5.0 and all is well again
Hi, After having succesfully used 6.5.0 on my PRO 6 since the day it came out, I upgraded to 6.5.1 today. The system fan started to act weird. When putting the fans on COOL, it took a little whi...
mdgm-ntgr
Oct 06, 2016NETGEAR Employee Retired
You could try setting e.g.
# echo 1000 > /etc/frontview/min_fan_speed_override
then
# systemctl restart readynasd
Supertramp11
Oct 06, 2016Luminary
Thanks to those who went to 6.6.0 and reported back on the fan behaviour. I continue to have a great experience with 6.5.0, unlike 6.5.1 and 6.5.2 and I hope that Netgear looks back at this version and "copies and pastes" the correctly functioning code into the future 6.6.1.
If not, 6.5.0 might be the final destination for my PRO 6..., which works great and is far better than the old OS 4. I just hope I won't accidently hit the wrong button on the automated upgrade pop-up one day.
- mdgm-ntgrOct 06, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig) just after seeing the problem on 6.6.0?
Supertramp11 sticking on 6.5.0 indefinitely is not something we'd recommend.
