error404
Oct 10, 2016Aspirant
Upgraded to 6.6.0 on RN214
I have just upgraded to 6.6.0 Now I find that Plex has an error "Application failed to initialize." Empy resource error. Bad NML call. Everything was fine before upgrade. ? I have the late...
- Oct 18, 2016
Rebooting your NAS and waiting a handful of minutes or so should lead to the problem being resolved.
jpcarro
Oct 15, 2016Star
I too was burned by this update. It's taking some time to address the changes needed by Plex Server. Meanwhile, I'm down...my ReadyNAS built for media streaming sits idle.
error404
Oct 15, 2016Aspirant
Thanks for the reply jpcarro
Glad to see its not only me on readynas forums,
That takes the time to post here about this issue,
I don't know why, but there seems to be more activity by RN214 users on plex forum than here.
Maybe thats a note for this forum about its users preference and usage of the RN214
- error404Oct 18, 2016Aspirant
When are you releasing.
readynasos 6.6.0+1 which includes the missing/updated pkgs.
- StephenBOct 18, 2016Guru - Experienced User
Netgear is on the hook to update any broken Netgear apps - I think surveillance is the only one.
The app developer/supplier is on the hook to update their apps. Some of them might choose not to. It sounds like plex is close.
yes because plex has found the errors in 6.6.0.
and it you use apt get update os goes to 6.6.0+1 and the missing packages are there.
so by looks plex debugged and readynas have updated on the quiet ?
Is this true
