gyves1's avatar
gyves1
Luminary
Mar 22, 2017
Upgrading manually some upgradable installed packages
Hi everyone,   I have some questions about upgrading process the installed packages.   I have done this command-line apt list --installed   and the result see https://intranet.vaultize.com/shar...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Mar 22, 2017
    Sure.
    Updating packages is at your own risk. You may wish to try doing it in the VM first. If you break the VM that's much less hassle than breaking the NAS. We do hold some packages back on old versions deliberately.
ProSupport for Business
