gyves1
Mar 22, 2017Luminary
Upgrading manually some upgradable installed packages
Hi everyone, I have some questions about upgrading process the installed packages. I have done this command-line apt list --installed and the result see https://intranet.vaultize.com/shar...
- Mar 22, 2017
Sure.
Updating packages is at your own risk. You may wish to try doing it in the VM first. If you break the VM that's much less hassle than breaking the NAS. We do hold some packages back on old versions deliberately.
mdgm-ntgr
Mar 22, 2017NETGEAR Employee Retired
That result page requires a login. Why not just paste the results in the thread?
gyves1
Hi mdgm,
Thanks for your reply
Because my result (list) exceeds to word limit of this forum.
May I send the result through the same way for debug log?
Gyves
